Track setup questions
Suspension mods are KYB adjustable front struts with QA1 275lb springs, UMI TQ arm, Spohn Panhard bar, and Lakewood Lower control arms with pre-load bars. Running M&H Racemasters 26x11.50x16 @ 12-14#
I had the car out a few weeks ago and the track was very cold and we were having issues getting traction on most passes.
Does anyone have experience with these lower control arms? I had previously put the car on the ground, installed the pre-load bars and then pre-loaded them so there was little squish in the rear, is this correct? I have considered raising the car and supporting the body and letting the rear droop and then pre-loading the control arms at that point, is this something to try?
Car has a best of a 1.64 60ft on motor, but I personally think it can do better. Any advise on setup/suspension is welcomed.
Johnny
