torque arm question
Old Feb 28, 2011 | 12:10 AM
20TA02's Avatar
Angry torque arm question
so i bought a spohn adjustable torque arm for my 2002 trans am, whenever i put it in 1st gear or reverse, it sounds like its hitting the body. anyone have this problem?
this is the torque arm i bought:
Old Feb 28, 2011 | 06:54 AM
sedanman's Avatar
are the bolts where the tq arm mount to the body mount tight?
Old Feb 28, 2011 | 03:40 PM
20TA02's Avatar
yes. i called spohn and they said it was a common problem and the only solutions i have are to beat the **** out of the torque arm (where its hitting the body) or raise it back to stock height.
Old Apr 6, 2011 | 08:52 PM
kidcamaro98's Avatar
I have the same torque arm. I am lowered on the eighback pro kit and with my 10 bolt I never had this issue....
now that I installed my 12 bolt, it is hitting in the tunnel. Its rather annoying but im sure it will "dent itself" after some hard pulls.
Old Apr 6, 2011 | 09:33 PM
peterlawl84's Avatar
Since you mentioned you were lowered, have you centered the rear with an adj. panhard rod?
After my 12-bolt was installed, my t/a was rubbing the body until I realized the rear was alittle off center.
Old Apr 6, 2011 | 09:52 PM
yah I have.
Old Apr 7, 2011 | 09:51 PM
INMY01TA's Avatar
The thud you hear is normal noise associated with tunnel mounted torque arms. If you had searched around here you would have known.
Old Apr 7, 2011 | 10:04 PM
tittan1500's Avatar
I used to get allot of clunking with mine, going over bumps or in light braking situatons .
The key was to tighten the **** out of the bolts that hold the pinion support
 Michael S. Palmer
