Line Lock Installation?
Old Feb 28, 2011 | 03:38 PM
l 95 Trans Am l's Avatar
Default Line Lock Installation?
How hard is the install and what all needs to be done to do it?
Old Feb 28, 2011 | 05:18 PM
slayer_taunu's Avatar
http://www.slponline.com/inst/25000.pdf
unhook the line from the master to the ABS block
put the line lock in its place
wire it up
bleed the brakes.
dont leave it unhooked too long, or else you'll get air in your ABS block and have to take it to the stealership to get bled with a tech-II
Old Feb 28, 2011 | 05:20 PM
msydow's Avatar
mine was ridiculously easy to put in. worst part is bleeding the brakes. and it is f*cking fun.
Old Feb 28, 2011 | 10:35 PM
SS SLP2's Avatar
LINE LOCK INFO
I uesd 11 years, still works great,when applied my front tires have never moved
LINE LOCK INFO
IS hole behind pcm , but I drill hole beside steering colum also ( drill from inside out ) put a peace of rubber hose in hole ran wire inside hose, then use same type wire wrap as GM,tie wrap to the big rubber hose comming over master cyl
I also mounted switch in ash tray
I have used this unit for 11 years with NO problems ( well yes one problem :::SLICK tires )
PS ::Connect brake line to master cyl and line lock ,the second line which goes to ABS block start it but leave it loose,remove cap from master cyl and let the lines grivity bleed watch the loose connection untill all air is out and run pure fluid ( may shake the line a little to help bleed ( REMEMBER BRAKE FLUID WILL REMOVE PAINT
I placed plastic sheet over fender)if does not gravity bleed blow into master cyl and have some one watch for fluid at ABS block >>>THIS way you do not have to bleed the brakes from under car- I had no problem of any kind
Sorry for the long post, hope it helps
good luck, have fun
Johnny
__________________
