Really weird suspension issue
Alright guys last summer, I exploded my 10 bolt and opted to go with the S60. Im using a UMI rear sway bar with the extended end links that were included in the box with my rear from spohn. After I installed the rear and everything was buttoned up I took it off of my lift and drove it around for awhile just to check everything. I looked under it at all the stuff I played with and everything looked perfect. Well a few months after that I jacked the car up to swap out my tires and I noticed the endlink bolt was actually bent. It wasnt like this before I jacked it up so I am wondering what caused the endlink bolt to bend when I jacked the car up? Sorry if I am a little slow lol but this is a weird freaking problem that ive never encountered. Thanks alot guys
Thats what I thought first to. When I got home from work today I replaced the end link bolts with new bolts same grade length etc and went for a ride and no issue (no holes hit for sure). I jacked the car up to sneek under and take a look ( i swapped bolts out on my lift but my dad had a car on it when i got back from the ride) and the bolt on the side I jacked up only was bent, almost like their is excess force being applied to the bolt when it is jacked up. The side i didnt jack was fine. Now it makes a clunk noise on that side when I drive it. Im ready to just do the end links that are adjustable and call it a day. I cant seem to put my finger on what is going on here.
