Front sway bar bracket bolts.
I took my sway bar and the brackets off last year while I was drag racing. I am putting my front sway bar back on but can't find the bolts for the brackets. 8 bolts total I'm missing. Anyone know the sizes of them? The dealership could not tell me what sizes they were.
Thanks. Now I know that they are 10mm. I've got my rear umi sway bar already installed along with everything else I've bought over the winter. Can't believe I lost those bolts. Anyone know exactly which bolts to buy? I doubt the hardware store is going to have the ones I really need. I think half the bolts are thick then slim down where the threads are. If anyone doesn't use their sway bar and have some bolts laying around, I'll buy them!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I just pulled my brackets off my 98 Z28 and measured the bolts because I was missing one bolt and had a broken bracket. The bolts I pulled off the brackets were 13mm wrench/socket head. M10 x 1.5 bolt with a 31.5mm UHL (under head length).
I was looking to replace them with ARP bolts so this is the closest ARP match I could find (I'm sure Lowe's or Home Depot would have something close as well if I wanted to do that)
M10 x 1.5; 35mm UHL; 12mm wrench/socket head
Black Oxide (662-1004) pack of 5 bolts
Stainless Steel (762-1004) pack of 5 bolts
p 85 of the 2011 ARP Catalog
Once I add a washer I'm sure it will be close to the original 31.5mm UHL. I hope that helps someone.
