antiroll bar install help
I just received in my ARB from Midwest chassis. I have emailed Eric for help but figured a post on here wouldn't hurt. Basically he told me to mount the bar and then get as close to 90 degrees with the links and bar and weld my tabs there. Well currently the car is up on jackstands. Will this affect anything or should I put the car on ramps so the suspension is loaded?
Thanks
Thanks
LS1Tech Premium Sponsor
We have it designed for a simple install. The links are adjustable so if they are placed correctly it is not needed to have the suspension loaded. the offset of the bracket goes to the outside of the car and make sure that the tabs are spaced 35" apart from eachother measuring from the outside of both, the same dimension theas the arms of the ARB itself.
Here's a few pics I found of the weld on style bracket from customers that had them installed.
