lower control arm not long enough
Old Mar 13, 2011 | 03:50 PM
Trl_ws6's Avatar
Default lower control arm not long enough
I have sporn on car adjustable lower contro arms and they have worked fine. I installed my relocation brackets today. Passenger side went just fine but the driver side is too short. I know I should be able to just wrench on the lower control arm and it become longer but i cant break it loose for nothing!
Old Mar 13, 2011 | 05:08 PM
Blwn_by_Twins's Avatar
Go inside, eat some Wheaties, break loose the adjuster.
Old Mar 13, 2011 | 06:15 PM
Trl_ws6's Avatar
Well am I suppose to just turn the center adjuster?
Old Mar 13, 2011 | 06:34 PM
lethal bird's Avatar
You need to break the jam nuts loose the tune the adjuster.
Old Mar 13, 2011 | 07:08 PM
stroked383HSR's Avatar
it might have got weathered in there.....a bunch of crap around the threads.
I had the same problem with my torque arm, couldnt bust it loose for nothing!!
your going to have to take the control arm off and break that puppy loose and screw it all the way out and clean those threads and the inside threads....and them it will turn nice when its on the car.
at least yours is a control arm and easy to get to......and not a freakin torque arm.
Old Mar 13, 2011 | 08:25 PM
Trl_ws6's Avatar
Ill remove it and degrease it then power wash it and see what I can do.
Old Mar 13, 2011 | 08:39 PM
sedanman's Avatar
You can try a little heat with a torch or you can try letting some PB Blaster soak in and it should break loose.
Old Mar 13, 2011 | 11:49 PM
krissoto's Avatar
def need to get it broke loose so you can adjust if if necessary, but take a ratchet strap and pull the rear end forward. If you didn't make any adjustments to them when you took it apart, you should be able to just pull the rear forward to line up the holes....
Old Mar 15, 2011 | 02:49 AM
Trl_ws6's Avatar
Thanks Krissoto. That worked perfect!
Old Mar 15, 2011 | 11:05 AM
krissoto's Avatar
no prob man
