Quick shock question
Old Mar 23, 2011 | 09:37 AM
cnd99hawk's Avatar
Default Quick shock question
Do Koni's come from the factory on the upper perch and how do you tell?? Also, how do you change from the upper to lower perch? I will be running Strano's shortly as stated in my sig and I know its not advisable to run on lower perch with them. I'm just curious how you tell, I just want to make sure mine are on the upper.
Thanks
Old Mar 23, 2011 | 10:00 AM
Sam Strano's Avatar
LS1TECH Sponsor
The come on the upper and should stay there if being used with lowering springs.
You simply slide the spring perch up and see which groove the clip is in.
__________________
