Does this look lowered?
Old Mar 24, 2011 | 01:34 PM
VandykeT/A's Avatar
Default Does this look lowered?
Old Mar 24, 2011 | 04:21 PM
leadfoot4's Avatar
Compared to MOST of the Z-28s I've seen over the years, I would say, "Yes", this one is lowered...not a lot, but inded lowered.
Old Mar 24, 2011 | 04:35 PM
Rauch's Avatar
Yes, a little bit. Otherwise, it'd look like a tank.
Old Mar 25, 2011 | 08:24 AM
speedracer2536's Avatar
nope stock height.. Take a picture of the shocks and struts.. Def. looks like stock from my end
Old Mar 25, 2011 | 08:39 AM
1badWS6's Avatar
It looks a tad lower but I wanna say its stock height. What size are the rims? It might be the rims throwing me off.
But yes, take pictures of the springs.
Old Mar 25, 2011 | 11:29 AM
VandykeT/A's Avatar
I got the car on a lift today and looked at it. The springs were dirty so i took my finger and wiped them off and they were jet black. I also noticed something strange on the passenger side rear two of the coils are together. The car gets very swirly in curves, trammels like crazy and rides like ****. Is it possible they're some kind of drag springs or just screwed up factory ones. I thought all my handling problems were because of bad shocks. I'll try to get some pics up in the next little bit. I don't know where the camera is so i may have to wait for my girlfriend to get home. Thanks
Old Mar 25, 2011 | 12:50 PM
VandykeT/A's Avatar
Old Mar 25, 2011 | 12:55 PM
VandykeT/A's Avatar
The rims are 18s. Its got a 275 35 18 on the back and a 255 40 18 on the front. I took my hand and wiped the springs off the best I could.
Old Mar 25, 2011 | 02:20 PM
KevinR's Avatar
The pic of the car looks like it's lowered, but the springs look like my stock springs did.
Old Mar 25, 2011 | 02:27 PM
lethal bird's Avatar
Im going to say stock with a coil cut is what it looks like to me.
Old Mar 25, 2011 | 02:34 PM
chaman's Avatar
Its stock.
baalic's Avatar
Looks like stock with worn suspension IMO.
Old Mar 25, 2011 | 09:33 PM
VandykeT/A's Avatar
So if i just buy stock springs for the back I'll be good? Do I need to buy them for a Z or a SS.
Old Mar 25, 2011 | 11:48 PM
67goatman455's Avatar
stock springs it looks like. but since one of your rear springs is touching on the coil...it looks like someone took a torch to them to try and lower it. the rears need changed asap for sure. it would be a safe bet that they heated the fronts too.
Old Mar 27, 2011 | 12:00 AM
VandykeT/A's Avatar
Are moog replacements any good from advance auto?
Old Mar 27, 2011 | 12:08 AM
chaman's Avatar
Yes they are.
Old Mar 27, 2011 | 12:13 AM
01SSRMS's Avatar
Yeah, the rear springs need to go.
Personally I wouldn't buy oe equivalent replacement springs from the aftermarket. There are just too many actual OE springs available for next to nothing. If you want to buy springs then I would look into some of the better performing versions out there. If you like a solid handling car I would look into Strano springs/Koni shock set up. If going for pure drag racing then find something more in that line.
Old Mar 27, 2011 | 07:39 AM
leadfoot4's Avatar
Moog springs are a quality item, but I would hazard a guess that they'd jack up the back of the car a bit...might not be what you're looking for.
Old Mar 27, 2011 | 11:45 AM
VandykeT/A's Avatar
what about doing the moog springs with the hose mod to set it back down?
Old Mar 27, 2011 | 03:37 PM
leadfoot4's Avatar
It's a possibility, but it all depends on what ride height the Moog springs would give you.
By Brett Foote | 2026-06-04 05:00:17
