HELP shock install
Old Mar 26, 2011 | 06:34 PM
jorgez28's Avatar
Default HELP shock install
Ok I am in the middle of installing the front shocks. I can't get the bolt off that is under the master cylinder I loosened it but still can't get to it. Are there any other tricks to getting it off?
Old Mar 26, 2011 | 07:40 PM
mike.d's Avatar
unbolt the master and move it over ther is enough flex in the lines
Old Mar 26, 2011 | 07:46 PM
joe77's Avatar
I second the above, you might also ahve to unblot the holder for the block thing all the lines go into, I know I did.
Old Mar 26, 2011 | 10:00 PM
bore.me's Avatar
Also called the ABS block and module, where all the brake lines connect. You can just unbolt the 2 master cylinder bolts but you will have to bend the 2 brake lines coming out of it a little to be able to move it out of the way.
Old Mar 26, 2011 | 10:22 PM
jorgez28's Avatar
Well I called it a night for today. I will trying and moving the block tomorrow.
Thanks ls1ers
Old Mar 27, 2011 | 05:27 AM
Undertow74's Avatar
just take out the 2 master cylinder bolts, and using some strenght just pull it out and up to clear the bolt you are taking out. you can pull the master right off the studs and let it rest on top of them, thats what i did. just as long as you dont superman it and bend the lines. but it moves out of the way easily
Old Mar 27, 2011 | 09:26 PM
jorgez28's Avatar
Thanks guys I finally finished is was rough. I did force the master cylinder out and this worked. Also for any one thinking of doing this remember to align the sting perch and the upper shock mount correctly to the holes on top because if nit you will need to compress the spring again. This happened to me. As for the shocks I am not sure I feel much of a difference between stock and Slp bilstiens.
