Ride height with Konis on lower perch and hose mod
I recently lowered my car by installing koni shocks with the stock springs on the lower perch and did the hose mod in the rear. Here is a pic of my car after install:
![](http://i295.photobucket.com/albums/mm147/cyteone/FILE0526.jpg)
Does my car seem really low? I was planning on putting in some lowering springs, but after the konis and hose mod I scrape my driveway when pulling out. I can go as slow as possible and it still scrapes the subframe connectors a little bit.
Does my ride height look normal for these mods?
Here are some measurements:
from the ground to the top of the wheelwell: front 25.5 in, rear 26.25 in
from the centercap to the top of wheelwell: front 14.25 in, rear 14.75 in
from the ground to the bottom of the body: 4 in at the jack pad in the front
from ground to the bottom of subframe connectors: 4 in
from the ground to the bottom of the wheelwell: front 5.5 in, rear 6 in
How do these numbers compare to a car with lowering springs?
doesnt look too lowered but your measurements look similar to cars with lowering springs if im not mistaken .. im on stock ride height and your car does look a tad lower then mine ..
I like the way the car looks and I don't really want to go any lower because it scrapes my driveway as it is. Driving around town it does not scrape.
I just thought the measurements were pretty low (comparable to a car with lowering springs) and was wondering why. Could my springs be sagging? I only have 72000 miles on the car.
The same picture is at the bottom of my cardomain page but it is much higher quality.
They weren't cut. I took them out a few months ago to swap shocks and I would have been able to tell if they were cut.
If they're sagging could I put in lowering springs and keep it at close to the same height? Or would it be better to keep my stock springs for comfort?
I mostly drive on the street but I was thinking if my car is too low shouldn't my spring rates be higher?
