Anyone have some good alignment specs?
I did use the search but they were some rather old threads.
Looking for some current input.
Nothing that causes very abusive wear....but something a little more aggressive than stock.
If choice has to be made to lean a little more on one or the other high speed stabil vs.....cornering...then I guess I would do high spd stable.
I use 0* toe, -1.5-2* camber, caster, I left stock, or even a little higher. And I got a 0 thrust angle in the rear. Dead straight on a flat surface, corners nice and very very stable at high speeds.
I havent noticed any abbrant wearing from driving, most of my wear comes from the few track days I do. But pronbably a good 20k+ on the tires and thought theyre bald now theyre worn pretty much perfectly even.
-1.5 is a little aggressive for the street IMO...
For the street and good double duty for the track I run:
Camber: -0.8L/-1.0R
Caster: +MAX
Toe Out: 3/32" total
If Im going to be going to the track A LOT, I will toss these specs in...
Camber: -1.4L/-1.5R
Caster: +MAX
Toe: 1/16"
I would suggest trying my "street" alignment. It works quite well for me on the street and on the track.. The other one I posted is quite aggressive and I find the car seeks and pulls in every rut in the road and it will wear the inside of the tires quickly.
Camber: -0.8L/-1.0R
Caster: +MAX
Camber: -1.4L/-1.5R
Caster: +MAX
Toe: 1/16"
Svthuh street specs should be tire friendly and work well.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
SVThuh I was thinking that on the camber as well but 1.0 on each side. but have heard of a little more on the right as well.
Sedan thanks for +1.
You guys ever try a kit like this:
http://www.summitracing.com/parts/LNG-78295/?rtype=10
I'm looking for something to measure toe accurately now as well...and am considering pulling the trigger on a purchase....becuz sometimes you just want to be able to change things and not have to wait. Or revisit things like an obsessed fanatic.
All I know is though it is, I never experienced it, but I also rotate my tires 2-3 times a season. So, maybe I just happen to get even wear because of that. Also, sinc emine lasted 2.5 years I call it good enough for me. But yes the slightly less will probably be easier on it overall.
collection of specs over the years:
Caster: +4.5* (aim for up to +5*)
Camber: -.7* (aim for up to -1.3*)
Toe: 1/32nd inch toe out
From Sam Strano when i had excessive outside tire wear:
-1.25 camber
1/16" total toe-in
as much positive caster as you can get
Mild Street Alignment:
0 Toe
-.5 Camber
+4.5 Caster
Slightly More Aggressive:
0 Toe
-.7 Camber
+4.5 Caster
Even More Aggressive:
0 Toe
-1.0 Camber
+4.5 Caster
The Full Race Setup
1/32" to 3/32" Toe Out
-1.3 to -1.5 Camber (whatever max is after the castor is set at 4.5)
+4.5 Caster
mitchntx setup
CAMBER: -1*
CASTER: +4.5*
TOE IN: 0"
-1.25 camber
1/16" total toe-in
0 Toe
-.5 Camber
+4.5 Caster
0 Toe
-.7 Camber
+4.5 Caster
0 Toe
-1.0 Camber
+4.5 Caster
The Full Race Setup
+4.5 Caster
mitchntx setup
CAMBER: -1*
CASTER: +4.5*
TOE IN: 0"
IF anyone would like a little info on auto alignment check my link below just keep clicking to get to info, need Java, give the site time to load then contune
and NO I do not want any work, have been retired 4 years
Johnny
I was aiming for:
-.25 Camber
5.5 Caster
.06 degrees toe in...which is supposed to equal the 1/16th recommended.
After floor touch down ended with:
-.4 left .2 right camber.
4.9 left 5.4 right degrees caster.
-.06 left -.07 right degrees toe in.
The camber once you sit in it...ends with -.3
Feels good so far.
Johnny
I found this factory spec online, is this really it? The positive camber seems really weird and I'm wondering why.
95-02 except 95-96 w/Goodyear Eagle RSA tire
camber 0.40* +/- 0.50*
caster 4.80* +/- 0.50*
total toe 0.00* +/- 0.20*
hold alt key then hit 248 in the number pad on right side of keyboard will give you the ° character. num lock light has to be on.
my 2002 gm service manual lists this
caster: +4.3° to +5.3°, preferred is +4.8°
camber: -0.1° to +0.9°, preferred is +0.4°
toe: -0.20° to +0.20°, preferred is 0.
the slightly positive camber will direct all the forces from the wheel to the larger inner wheel bearing versus the smaller outer wheel bearing, and promote longer wheel bearing life. this can be especially important on 3/4 to 1 ton trucks.
under high speed the air resistance will cause the suspension to drop
when the suspension drops, camber goes negative.
the +0.4° of camber which is not much will keep the tire riding flat in the sweet spot .
when the wheels turn,the outside wheel will gain negative camber so cornering is not affected... for normal/legal driving conditions.
