I think my brakes are dragging HELP
ok so the past few times ive had my car on the highway it will start to vibrate and drone really bad in the car and feels like the brakes are dragging and slowing the car down. i recently determined it is my front right brake that is sticking because it was about 200degrees hotter then the rest of the brakes after driving a half mile. What do you think could be the cause of my sticking brake and what should i do??
Check the caliper pins and check the wheel bearings.. The front hubs on our cars are not the best design out there for sure. Too much play could cause the vibration you are feeling and can cause the brake pad to drag on the rotor showing you your increased brake temps.
