Clunking/Popping Noise
just installed 3 point sub frame connectors, lca relocation brackets, adj torq arm and relocation bracket. i have made sure every thing is tight multi times, pinion angle is set to factory, car is at stock ride height, under light to heavy acceleration i can hear/feel a clunking from the center area of the car, i checked my lca bushings and they look to be good, any ideas?
Sounds like your Torque arm is making that clunking noise.
I have an aftermarket torque arm with a front Heim joint & mine clunks.
Your torque arm might have a bad grommet. If its an aftermarket torque arm that is not attached to your trans with a front heim joint....change it to a rubber style grommet.
its a new umi unit, installed it last night. its got poly bushings on the front where it mounts, did a quick search and it seems like a few people have this issue with no fix... or pin point on what exactly the noise is.
