Anyone running HAL Coil-overs on thier F-body?
So I scored a set of these a while back - coil-over fronts and just the shocks for the rear.
Since I have a completely Tubular front end (K-member, upper and lower a-arms) and the front is a little lighter, it sits a little higher than I'd like.
I'll be removing Sportlines/Bilsteins in place of these.
For those of you that have them, how do you like them for a DD?
NIght And day difference from an OEM style set-up?
Thanks.
Thanks.
i have them, yes, they have better weight transfer when you dial down them down to one or two clicks. And yes, they do ride bouncy unless I dial them up to 11 or 12 clicks and then they are pretty rough. But I live with them because they do give great launches at the track and I also street drive them a lot.
