what to do
Old Apr 17, 2011 | 12:23 AM
Ls1 Havin Fun's Avatar
Default what to do
ok well i already put on the new springs and struts in the rear but the front left suspension bolts on top( under the hood by the brake fluid cap) well the star bolt wont come out because its stripped. what do i do....i cant get it out
Old Apr 17, 2011 | 07:49 AM
3 pedal SS's Avatar
The easiest thing to do is take a grinder with a cut off wheel and cut it off. Install a regular headed bolt. You can try a chisel with a sharp edge and hit the bolt head in the loosening direction.
Old Apr 18, 2011 | 05:43 PM
lsx24's Avatar
Vice-grips might work if you don't have air tools.
Old Apr 18, 2011 | 08:02 PM
guy7bmwm83's Avatar
Or try to make two flat spots on the bolt head edges so you can use a wrench.
