Uneven suspension in front what could it be?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
My girlfriends 96 camaro z28 seems to have uneven suspension travel in front. for instance when traveling at low speeds I watch the A-pillars of the car go up and down independant of each other on a flat road.
Ride seems bumpy in front too. The effect is magnified when I increase tire pressure to 40 psi from 35. it is pretty noticeable.
I have tried several different wheels and several different tires including two tires that were just high speed balanced and still the same problem as before.
I did take the struts out as I was thinking of lowering the car for her but she changed her mind. Susupension is stock. Was there something that could have gotten out of whack when I removed the springs/ shocks?
