Help finding FRONT lowering springs
I've been up and down most of the popular websites looking for a set of front lowering springs with no luck. I do not want to lower the rear due to my dumped exhaust set up which already low as it is, and I do not want to buy a whole set of 4 and pay for more than what I need. I did however see that QA1 sells a set of front springs but with no info on whether it changes ride height, I guess could cut a link off if needed. Goal is to fill the fender gaps by lowering the front and use a taller tire in the rear, but I also want a stiffer spring up front for handling, that's why I haven't just cut the stock spring. Anyone?
Heres a front and rear set:
http://www.stranoparts.com/partdetai...D=20&ModelID=7
This will give you WAY better handling then lowering springs on stock shocks, while also better ride quality as well.
LS1Tech Premium Sponsor
Like 99Bluz28 said we do sell our front springs by themselves, the part number is SP002.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
http://www.daymotorsports.com/shop/S...Coil-Over-Kits
Lots of choices for a threaded collar coil-over setup. $40 for the sleeves and an infinite ride height. Just know the diameter of your shock.
And that will put you here ...
http://www.daymotorsports.com/produc...L_OVER_SPRINGS
Choose which free length and rate you want.
Then just move the lower seat up and down the threaded collar to find the front ride height you want.
