Running Kooks w/ORY--What torq arm?
Sup guys, im building my 30th anniversary and i almost got everything but I need a torq arm set up. I dont plan on drag racing every month but still want to be able to plant my tires when i want. After i break my 10 bolt i do plan on buying a Mid West 9" so what would you guys recommend??
Running Kooks 1(7/8) with 3" ORY and Magnaflow Catback....
Friend of mine is running the Kooks, Kooks Y, Magnaflow cat back. Purchased the UMI T/A with relocation mount. The reason for choice was it mounted to the 10 bolt as well as the 12 bolt that eventually found it's way under his rear. The conclusion was a one time purchase that covered two bases. The local rear end guy that was consulted prior to purchased was not in favor of a 9 and felt the 12 was a great choice for the car. HTH
Hello,
Is it a Kooks ORY as well? We have three options for torque arms for that set up if it is. I posted a few links below, the longer transmission mounted item is a more streetable set up while the short arms work great at the track. Please take a look and let me know if you have any questions.
Transmission Mounted Torque Arm
Tunnel Mounted Torque Arm
Tunnel Mounted Torque Arm w/ Loop
Thanks!
Ryan
Thanks!
Ryan
