UMI non adjustable torque arm question
If I use taller than stock drag radials at the track do I need to have the adjustable torque arm? I currently have a 28.0" rear tire and probably am going to go up to closer to 30.0" next time I buy tires. I have the UMI relocation crossmember that has some adjustment for the front mounting point on the torque arm but I do not know if this changes pinion angle slightly enough to compensate for the taller rear tires. I do not plan on changing anything else that will affect ride height and wanted to know if I would be fine with the non adjustable arm. The only reason I am not just buying the adjustable crome moly is that I am pretty broke even though I know its better its also more than 40% more money.
1999, adjustable, adjustible, arm, camaro, ls1tech, nonadjustable, suspension, ta, tork, torque, umi
