Umi and TSP
Also, this came off a moser 12bolt and is going on to a moser 9", what adjustments need to be made to ensure the torque arm is angled properly? I know it has to be near perfect so what do I do? It's still adjusted the same as it was on the other car
And the pinion angle is set the same for the different rears as far as I know.
Your best bet is to sell the tunnel brace and arm on the parts classified and use the money toward a full length bar (and I recommend the relocation crossmember as well), or reconsider TD's and go with a Y-pipe set-up.
