High speed vibration and I checked EVERYTHING!
OP, are your SFCs welded? If so, on a 2 post lift?
Here is my ongoing thread:
http://camaroforums.com/forum/4th-ge...ss-shop-62293/
That's the way I was told to do it by multiple suspension people. Was that right?
For those of you who were following this thread I finally got it the other day. I can't stress enough to everyone out there to do the work yourself. This way you know it's done right.
The other night I was trying to sleep but couldn't get this vibration issue out of my head. I can't explain how I came to this conclusion but I saw a quick image of some stick on wheel weights on a rim and it got me to thinking. The shop that balanced my wheels, twice, used stick on weights only. If any of you have ever worked in a tire shop you will know that just putting the stick on weights in the middle of the rim will ALWAYS result in repeat vibrations.
I went to the auto hobby shop on base and balanced my wheels myself checking them for imbalance first. None of them were WAY off but all of them were out a little. The worst is still the driver's rear wheel. It has an up and down hop that is either the whell or the tire but the vibration is nearly 90% gone now.
Any one think I have a legal leg to stand on here? I think that if the job was done right the first time or even second time, then I would have never had to go replacing my car from the driveshaft back. Someone needs to be made accountable for this HUGE mistake.
Yeah I used to work at a tire shop, before joining the army and when I was stationed in AZ I bought tires from pepboys for my wifes pontiac vibe and they put on sticky wheel weights. I inspected the wheels really well and I they didnt even clean off the brake dust before throwing on the sticky weights. So I went 5 miles down the road, drove back and showed them the wheel weights coming halfway off already. To top it off one of the tires where brand new when i bought the car the other three where shot. So I told them to put that tire in the back of the car because there was no use in throwing away a perfectly good tire, but I wanted a new even set all the way around on my wifes car. So they put the tire in the back of the car alright... with armor all and grease everywhere. They didnt bother putting down plastic or putting it in a trashbag or anything. Looked like the guy chucked it in the back and it bounced around and touched almost every surface of the back. Needless to say they ended up paying a 100 dollar detailing bill i brought to them. But COME ON, some guys have no friggin common sense.
It really is terrible that this was all it was. Yes, I have a great suspension now but that wasn't what I wanted to have to spend money on.
When I worked at NTB back in 00-01 we would get repeat cusomers all the time with sticky weight issues. Most of them just did like I did and said **** it with the pretty look of the wheel and used hammer on weights. I really can't believe I didn't look into this before but to have re balanced them a month down the road with the same result...... I just don't know man.
I imagine that a new set of wheels (custom or aftermarket) and tires will eliminate everything. That was my goal from the start but I'm still undecided on what wheels to run.
If you have some sort of documentation showing the tire shop screwed up with their stick-on weights, and then showed negligence (or something like that) towards fixing it, it seems like you could at least get some free tires. But without documentation they'd prolly just laugh at you
Sticky Weight > 9" Simpley incredible
