Rotors Moving/Clunking
Hi I was wondering if anyone ever figured out why this was happening. I am having the same problem with the rotor moving when going from reverse to drive and visa versa. And for those of you saying that it can't be the rotor it is. I marked the rotor and my rim put it in drive and moved a lil bit and hit the brake, heard the clunk and then checked my marks and they were not lined up. I've called the technical support and they basically said that it's impossible and that there was something in the way. I've checked 3 times myself and even had a mechanic look at it and it's still happening, even when I over torque the lug nuts. I can't figure it out so if anyone has an answer please let me know. The only thing I can think of is to return the rotors and get a different set. Thanks.
