SLP Bilstein's in stock... Still $384.99/set
SLP had a price hike on these, but I decided to hold the line on the pricing as long as I could, so the price is still $384.99/set. Sooner or later they will be going up to around $399/set.... but not yet. So if you are looking for some, I've got them in stock ready to ship!
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
As for the HD question, I think there is some confusion on your end on that one. HD's are "regular" Bilsteins. SLP's and HD's are the same valving now (never used to be), and we can buy and sell "SLP's" cheaper than "HD's" in bulk.
If your car is lowered, and you want it to work as best it can for as long as it can then I would recommend a Koni. However, the Bilstein's work well on moderate lowering springs for a few years, and many opt to do that way to save the $500.
__________________
They are.
__________________
:hmm: I'm looking to replace my Bilstein HD's that I've had on the car since '05. Running Prokit springs that will also be replaced, as well. I wanted the car to ride better and considered spending more money, but wasn't sure which shock to go with. Sounds like Koni's are they way to go, but is the difference significant?
Yes, it's a huge difference. I don't know why folks think Koni and Bilstein are so similar other than both are good quality and from Europe. Beyond that they are not more alike than a Audi vs. a BMW.
Koni's set down at full soft are similar to Bilstein's... nobody I know who has Koni's (and therefore the choice of damping levels) opts to run the Koni's at that setting.
__________________
No. To begin with, what I'm selling are new, not 6 years old. Further, the valving of what I have is different than HD's from that time period.
__________________
6 years ago, the ones I currently have on my car were new, so that's irrelevant. All I was asking was if it was the same shock, just under a different name, was all.
It's not irrelevant, what you have have 6 years of wear. A lot of folks think that shocks never get any weaker (not saying you are one of them), just pointing out that aside from the fact the valving is not the same, even if it was---the actual amount of damping force wouldn't be the same.
6 year old HD's are not the same as current HD's, which *are* the same as current SLP's. Current SLP's aren't the same as 6 year old SLP's either.
__________________
Well it's the internet, common sense is severely lacking. Don't take it personally, every time I assume someone would know something I'm usually proven wrong. And since others are reading this, I kind of try to make things plain.
__________________
Bilsteins are miles ahead of the stock shocks. My car pitched and wallowed over uneven pavement on the stockers, now it is much more controlled. My stock springs are cut a coil for a 1" drop and the car rides much better with the Bilsteins than it did at the stock 4x4 height on the stock shocks.
It's a 99 transam with 18" wheels with 40,000 miles, thanks colin. Oh my avatar pic you see hear is before it was lowered.
At some stage was about 12 years ago. Seriously when you feel the difference you'll be stunned.
This is a conundrum. Koni's are certainly better long term, and offer that much better control when driving the car spiritedly. But your stock shocks are so poor that the Bilstein's would look amazing in comparison. I guess it's a matter of how far you want to go. No shock will cause your spring drop to disappear.
__________________
More planted in the corners, yes, and less boucing as well, but it still rides horrible.
How about bilstein up front and konis on the back?
I purchased the bilstein/strano springs combo from you last christmas, and now I am thinking about getting konis for the rear. will it produce a noticeable gain in the handling department?
