Best pad/rotor combo for F-body
I keep seeing people using this argument but it just tells me they don't know what they're talking about.
It's not about the amount of material but the surface area. When you drill hole or slot the disc you're actually increasing the area. The naysayers will say drilling decreases it but they are not seeing the whole picture. When the disc is drilled the whole thickness of that hole in the disc is part of the surface area now. Same as when you slot it. And yes I know the main reason holes were originally there was to help with off gassing not cooling and slots are to help pads have a cleaner surface to bite.
There are plenty of white papers that go into both brake theory and real-world practice, if you doubt physics.
This is what I was trying to say bout the decreased mass, it really is not all about surface area as you would think.
I don't know if you have ever seen a real race setup brake kit for hardcore autocross but those things are beasts, the rotors are extremly thick, heavy, and have no slots or holes, they are desighned to do one thing and one thing only and thats last a entire race without getting to hot because if they get to hot then they degrade the PAD and the PAD is what does all the work.
If your brakes are going to see alot of hard heat and cool down cycles like drag racing a blank style rotor will probably hold up longer. cheep crossdrilled rotors will probably wind up failing, however if you buy a GOOD crossdrilled rotor, or a rotor that was CAST with the holes in it then you will fair better, remember you get what you pay for.
and you cant go wrong with hawk hps pads or hp pads. concentrate more on the pads than the rotors,
First off OP nice Avatar!!
I'm running Brakemotive Slotted and Drilled rotors along with Hawk HPS pads and could be happier. My TA is my DD and it sees around 300 miles a week in the hot texas 100+ heat. My brakes grab strong and don't fade out like the stock set up. I don't autocross my car or anything, but even slowin from 120+ after a race my brakes hold it. Hope this helps ya
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I'm kinda stuck between good quality blanks and slotted rotors now. More research to do
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
So with what you said then a Brembo blank like above would work well with the hawk pads then?
http://www.summitracing.com/parts/HWK-HB249N-575/
Are these going to be too aggressive?
http://www.summitracing.com/parts/EBC-DP31239C/
Or these?
http://www.summitracing.com/parts/EBC-DP41239R/
Or these
My car is not my DD. It is a toy. It gets driven in the summer whenever I feel like it which is usually a lot, but not in rain and not everywhere so I guess a completely street oriented pad can be skipped here and I could probably get away with a little more aggressive pad. I'll probably put 3-5k a year on my car.
Or these?
Or these
Wow I just looked at the same Hawk HP plus pads for 30 bucks cheaper on WS6 store!!!
I know where I will buy the pads I buy at...
I think I am going to get these...http://www.ws6project.com/user_stor/...nt-rear-save-/
That "new" surface area isn't cooled effectively, and you're still reducing the total mass of the rotor - which means it will heat quicker, cool quicker, and be more prone to warpage and cracking due to that.
I'm not saying that crossdrilling is the best thing out there. I'm just saying that it's not as bad as a lot of you are accusing them of being.
Also some, not all of the pictures that I've seen of "cracked" rotors actually only show surface indications in the swiped area. Which would be more an indicator of the quality of the material than stress from the crossdrilling and is more than likely not that detrimental for normal brake use.
I was involved with Metallurgy when I was in the Navy and I took physics in HS, so I'm not some ignorant redneck, heavy equipment operator from NC. But I am a redneck heavy equipment from NC.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I look at it like this... What do all the top road race cars... and supercars have as rotors... Slotted and cross drilled rotors. I say with all the money they have to do research to make there cars brake fasterto get a second less on lap time... there must be a reason all of them choose them. None the less whatever you choose will be right for you. Good luck with your decision.
Yes, I've read SAE 2006 -01 -0691 " The Effect of Rotor Crossdrilling on Brake Performance. If I recall correctly it was pretty favorable conclusions to cross drilling concerning cooling.
I was involved with Metallurgy when I was in the Navy and I took physics in HS, so I'm not some ignorant redneck, heavy equipment operator from NC. But I am a redneck heavy equipment from NC.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
The majority of white papers I've seen (from some of the larger brake manufacturers themselves, who, given that cross-drilled and slotted rotors are more bling than boring old blanks, would pad in favor of the drilled and slotted rotors for a marketing standpoint) all show that, for 99% of the vehicles out there that have cross-drilled and slotted rotors on them, the "pretty" rotors don't do anything better, and are more prone to issues like hairline cracking, premature warping, and the like. Granted, a lot of people who buy them aren't going to drive their car hard enough to see those issues, but they still exist for the guys who do drive hard.
But, like I said, that's just my opinion that I've come to over time. (Been a long week, so I don't want it to seem like I'm trying to start a pissing match or anything). If you disagree, hey, that's why they make both types of rotors, right? So everyone is happy. :beer:
#33
Ok with all of the is cross drilled bad or not, will I ever put that much stress on them continually like a dedicated road course car to heat them up and crack them like the stock ones, or the ones that you saw that had failed?
I'm really trying to just get the best bang for the buck. While not being a complete cheap ***.
#34
Hey BrakeMotive I have a question for you...If I paint your rotors with a high temp brake caliper paint how long will it take to wear off. A day? 2 days? Week? Any idea? I really like the(puts suit on)look of the all black speed inc rotors I posted up, but your deal is kicking me in the nuts if I don't do it![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
What do you think?
What do you think?
#35
To the original poster, I would pick up a set of these since they are on sale, call Brakemotive (great guys) and order up a set of rear blanks, (no holes or slots, not needed) and buy a set of his Z-16 pads x4. Flush your lines with new Super Blue fluid, Summit has it for like $15/quart, and you will have a system that will completely amaze you. It will be even better if you pick up some Stainless lines, I think WS6 store has them cheap.
Good luck.
And, yes this topic has been beaten to a pulp and so has the holes and slotted question.
One tip, go to the sticky section and there is a whole write up on the drilled and slotted questions and quotes from all the major manufacturers on them being really more for looks now.
#36
#37
Ok, I'll stop now...LOL
#38
Oh no man I appreciate all the info you just gave me because it was what I was looking for.
I think I am going to go with the low line hawk pads and the brembo blanks you guys showed me.
Thanks for all the help.
I am still waiting on a reply from brakemotive about painting his rotors.
