Edelbrock Torque Arm
Old Jul 25, 2011 | 09:14 AM
Mystery Bird's Avatar
Default Edelbrock Torque Arm
Are they any good? I have an opportunity to pick up a used adjustable one for a good price. I don't know if it will help me at my level since I'm cutting pretty good 60's with the stocker. Opinions???
Old Jul 25, 2011 | 09:37 AM
TROYCO's Avatar
I have an non adjustable one, I'd say they're every bit as good as almost any other tubular torque arm. Any brand is definitely an improvement over the stocker.
Old Jul 25, 2011 | 10:17 AM
Badazz 97 TA's Avatar
What's ur 60fts?
Old Jul 25, 2011 | 10:20 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
In my opinion they are not nearly as well built as our BMR torque arm and this is for a couple of reasons. The rear mounting bracket they use where the torque arm bolts to the rear end is considerably weaker than the one we produce due to the size plate they use to build it and lack of bracing. I know with the older Edelbrock torque arms they used a smaller tube diameter to build their torque than we do, I know we us 1.25" diameter tubing so you may want to measure the tubing. Also they use the stock style formed metal end that slides into the bushing, this is not nearly as good of a design as using the tubular style front on the torque arm. Using the tubular style front spreads out the load were as the the formed metal front piece that the Edelbrock torque arm uses puts a lot of pressure in one small area due to the design. I have had more than a few customers bend and break their Edelbrock torque arm so I would definitely see what your other options are becasue there are much better designed and performing torque arms out there like the BMR one we build. I hope this helps out a bit.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Depending on conditions usually 1.55 to 1.62.
Old Jul 25, 2011 | 10:23 AM
BMR Sales2's Avatar
Man I am suprised your stock torque arm has held up to those sixty foot times, I have a handful of bent ones here at the shop.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jul 25, 2011 | 10:53 AM
COSPEED's Avatar
Yes there is a couple guys I know still running the stock torque arm running those 60 foots amazingly enough. An aftermarket BMR or UMI would not flex like the stock one would though under launch. I believe the plate on the back brace of the UMI and BMR are thicker than the Edelbrock.
Old Jul 26, 2011 | 10:14 AM
01ssreda4's Avatar
Auto cars can 60 like that will stock suspension. M6s cars cannot. Big difference between the two drivetrains and what they break.
Old Jul 26, 2011 | 10:29 AM
BMR Sales2's Avatar
I have even had some auto guys bend the factory torque arm but you are absolutely correct with the T56 guys having more issue with the stock suspension.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jul 26, 2011 | 10:33 AM
tim99ws6's Avatar
I have broken two adjustable edlebrock TA's and seen another break on a friend's car.
No thanks....haha
UMI/BMR are great choices. Midwest and Madman also make some more race-oriented pieces as well.
Old Jul 26, 2011 | 10:40 AM
I guess I'll pass on the Edelbrock then, thanks everyone.
Old Jul 26, 2011 | 11:04 AM
BMR Sales2's Avatar
If you are interetsed in one of our BMR torque arms give me a call here at the shop and I will see what I can do on pricing for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jul 26, 2011 | 11:21 AM
I'm afraid too. I know you'll talk me into something I just don't quite have enough money for, or the CC with come out.
