bolt in relocation brackets?
Old Mar 2, 2004 | 11:57 AM
ARTY99z's Avatar
Default bolt in relocation brackets?
I was ondering how they are and if anyone has had any problems with them? If i wanted to could they be talk welded for more strength?
Old Mar 2, 2004 | 12:46 PM
jimmyblue's Avatar
Moderator
No problems with mine, easy install, can be welded
(you would probably pull them off and grind the area
bright where you will be laying the bead). The bolt-
in kind appear to be heavier gauge than the weld-ins,
I know the bolt-ins are beefier than the stock LCA
pivot stamping they bolt onto.
Old Mar 2, 2004 | 01:17 PM
ARTY99z's Avatar
Thanks, how do you like your hotchkis springs? I have Eibach now and im looking for a little more ground clearance. HD Bilsteins will go in in when i figure out what springs to use.
Fulton 1's Avatar
I haven't had any problems with my bolt-ins. Installation was straightforward and they index using the lower shock bolt. As jimmyblue noted you can weld them if you want. Actually, I'd almost be inclined to recommend welded bolt-ins vs. straight weld-ins myself. Just IMO though...
