K Member Install
The install is pretty straight forward like mentioned. If you get to a frustrating point step back for a little, have a beer and come back. No matter what you do these things always fight a little... especially on the ground. The motor mount bolts are tough to get lined up, so don't force them with a hammer or it could bend the mount on the K-member. I think Jerry likes to line up the motor mount bolts first then the 6 bolts in the frame.
Good luck and let us know how it goes!
I used moving dolly with four wheels to position the motor under the car. Then with two jacks, I slowly lowered the car to meet the motor and K member. I used a PA racing k member and when I say I mated the car with the frame it dropped right in the alignment pins and I bolted it stright up no issues.
Make sure you got the new bolts, I needed to get shorter one m12x 1.25 30mm long I do belive.
Hope that helps.
some helpful hints already in this thread...thanks
