Strano Performance Sway Bars--IN STOCK
Price is $369.98 for the set of front and rear. The BEST VALUE around for any hollow bar set. Not to mention the *ONLY* bar set to have proven their worth on handling applications winning multiple SCCA National Championships!
http://www.stranoparts.com/partdetai...=126&ModelID=7
Strano Performance Parts was the first with a set of 35/22mm bars, the first and only with those sizes in a Hollow setup saving a lot of weight. We also supply all new bushings, heavy duty steel bushing brackets, and Teflon based grease with every bar.
You can run heavier bars, you can run other hollow bars.... but none give you the combination of balance, weight, and proven performance that Strano Performance Sway Bars do.
Available front or rear only as well.
Front: http://www.stranoparts.com/partdetai...=126&PartID=23
Rear: http://www.stranoparts.com/partdetai...=126&PartID=24
__________________
