lca/phr bolt sizes/grade
Old 08-03-2011, 10:46 PM
bpittman's Avatar
Default lca/phr bolt sizes/grade
What size and grade are the rear lca and panhard rod bolts?
Thanks in advance!
Old 08-03-2011, 10:52 PM
sjsingle1's Avatar
https://ls1tech.com/forums/suspensio...-lca-slop.html
dont use stock sizes
Old 08-03-2011, 11:48 PM
02TransAm/Batmobile's Avatar
I'm not totally sure (have to check) but I think I have a used set of 10.9 grade bolts for the LCA's and Panhard bar by UMI performance. They are 10.99 a set off of UMIperformance.com. I can do 15 shipped if you are interested.
Old 08-04-2011, 04:10 AM
sjsingle1's Avatar
my way is cheaper........you can get the bolts anywhere
Old 08-04-2011, 08:04 AM
UMI Performance's Avatar
The lower control arms will use a M12x100mm grade 10.9.
The panhard bar bolt is a step bolt that steps from a 14mm shank to a 12mm thread. This bolt would need to come from a GM dealer or reuse the stock one.
I hope this helps,
Ryan
Quick Reply: lca/phr bolt sizes/grade
