brakes and SFC's
Hi Reb,
Good to hear your looking and learning on the site. I too read and seek out all the info. I can find. As you can see, there are many folks here that have good ideas.
As for SFC's, the addition of these to your T-Top car will make ya really happy. They not only help the suspension, but also reduce the onset of the 'F-Body' sqeeks...lol
There are several good companies posted on the right------->
that are all sponsors here. Check them out and call em up. Support the companies that support this site. As for brakes, as PSU advised, there is much too consider. What type of driving will you be doing, i.e. track autocrossing, drag, etc. Best bet here is too read, make an honest decision, and spend wisely. We all were your age and on fixed budgets. Get what you can afford and what you desire...and have a blast.
Good Luck,
Kev
Good Luck,
Kev
Originally Posted by mitchntx
2 whole track events last year? Wow!!!!
Please ... tell me more. Educate me.
Pre cracked ... err, cross drilled rotors are the real thing, eh?
So, are all those little tiny cracks at each and every hole normal? And how in the world is all the ventilating supposed to take place with the holes plugged with brake pad material? I need to know ...
Maybe it's cheap *** rotors?
I knew those *** clown imports couldn't make anything worth a **** ...
For what it's worth, the rotors and calipers were adapted to my TA off of a 2001 Porsche 996TT. They are 13" x 1.25" rotors and 4 piston Brembo calipers. Those rotors have seen 2 sets of Pagid Black pads and over 11 track weekends, probably close to 8K miles, in the last 2 years.
They only come in C/D form and those tiny cracks formed almost immediately. The damn holes have to be cleaned out with an oxy/acetylene torch tip cleaner. They fill up after 2 or 3 pumps of the brake pedal.
C/D rotors are driveway jewelry ... that's a direct quote from someone much smarter than I ...
http://www.wilwood.com/products/kits...6bbhub_big.jpg
look at the crossdrills on those rotors
http://anomaly.cx/firebird/images/Wi...s/P7020005.JPG
those are the same rotors after 6 months of daily use with a race pad. No cracks, no problems.
For the C/D fans out there, I give you the all time greatest post in the history of the internet ...
http://corner-carvers.com/altimathread.php.html
It seems to me that one of the problem lies in taking the manufacturers literature at face value without thinking about it. A statement in a brochure such as "Our XXX model drilled/slotted rotors will (insert performance terms here) better than OEM rotors" is vague in that is doesn't state why they are better. The new rotor may perform better since it is larger, has improved materials/manufacturing, treatments, etc compared to OEM, but the fact that its drilled/slotted doesn't impact the performance. That is simply an additional feature. In fact, it looks like a rotor with the improved materials, size, etc, but not drilled/slotted might perform even better. It would be like a computer company stating "Our new X.XXMHz desktop with acrylic case will outperform your old CPU". The statement is true, but the fact that the case is acrylic has little impact of the performance. So the manufaturer isn't giving false info, but they aren't being really precise either.
