Taking LCA relocation to the extreme
think it sed the 3 1/2 can be adapted IIRC :/ but yah if you cut off the fac mnownt all to gether & replace it with one that has mutibil mownt points it's lighter, stronger, cheeper & fully adjustibil. same as for the phb mownts
thay allso have a wats link for like $60 & bolt on phb mownts one culd use to fab up your owne set up, just wuld have to make a chase mownt.
it's just some stuff I fownd, that I'v ben looking @ / thinking about.
https://ls1tech.com/forums/suspensio...-rear-end.html
It worked but because of ride harshness, binding because of fighting the OEM torque arm, and only work with OEM LCAs',it was abandoned. The middle hole of the LCA relo was bracketed to the holes in the OEM LCA. The bolt in bracket/strut to accomplish it had to be tightly dimensioned to what was on the car and had no flexibility to be able to fit on another vehicle. It lacked the 'universal fit'.
Currently in re-design to attain a 'universal fit' along with a 'lift bar' effect.
