Will I feel/notice Lcas,phb and subframe connectors all at once?
#41
If I remember right a member on here a while back (LSGun i think) installed a 12 bolt on his car and hated it for handling.
Why do you want a 12 bolt anyway?
#43
It depends. Since you want to handle you should keep a full length torque arm, otherwise the geometry is compromised under braking. You could consider a torque arm relocation crossmember to get it off the tailshaft though. What you choose will depend partly on what rear end you go with.
As far as the 12 bolt, it is heavier than the 10 bolt. But it is stronger. You aren't really going to get the light weight of the 10 bolt with more strength. I would say the biggest question mark is what differential is in it. If it is a locker or spool it will be useless for you. The other issue is with torque arm nuts coming loose on the 12 bolts, which is why some people bypass them for 9 in based rears.
#46
I have someone local to me selling a 12 bolt moser with all the upgrades and a watts link setup with torque arm etc..
You guys think all that will at least be VERY noticeable ? I'd have to save up a bit but its a decent deal for all the parts. I would do sfcs and lcas a the same time too. New diff will have 3.73s too.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
