Camaro and Trans Am suspension the same??
Wanting to knw if the suspension is the same like shocks and spring wise. I raised my camaro ss up stock height about a month ago using trans am shocks and springs and it looks a little high in the front need some help thanks
Same springs and shocks for Z28, Formula, TA, WS6 and SS. The WS6 and SS only get a bigger front sway bar which won't effect ride height.
The front probably just needs to settle and/or you to get used to the 4x4 look again, lol.
Some Z28/TA and SS/WS6 came with DeCarbon shocks or the optional Bilsteins. There are also different sway bars as well. As mentioned above, these shouldn't affect ride quality at all. If it's sitting too high, then it's stock. ;-)
