so what upgrades should be done to my suspension?
Yes, and that is actually a great idea to contact Sam. Sprung weight is the weight carried by the springs, unsprung is the opposite, the wheel, brakes, and axle are all unsprung.
I encourage you to take a look at a couple of our handling packages which will be well within your budget and make a big impact on your cars performance.
Sway Bar Package
We can build you a custom package with the weld-in relocation brackets if you're going to the S60 rear since you may run into problems with the bolt-ins seen in the package.
Lowering Spring Package
Give me a call at the shop and let me know if there is anything we can help you with.
Thanks,
Kevin@BMR
813-986-9302
Sway Bar Package
Thanks,
Kevin@BMR
813-986-9302
