No difference after koni's in front
Is there bumpstops for the front suspension? I have seen where people put the spongy bumpstops on the shock piston. Where can I find those? Can I get them at a local autostore- good ones that is? Any recommendations?
Here is where you guys will try to beat me up. I'm using these with factory cut springs. I took off 1.5 coils, like 10 years ago. I'm wondering if doing this made them 'wear out'. The ride height has not changed over the years though. The car actually sits higher than a Pro-Kit. Its maybe an inch lower than stock?
I am going to get BMR's lowering springs for the front and do them with the bumpstops. Think this will help? Anything else?
Also, would running uncut factory springs in the back and BMR lowering springs in the front make turning react in a weird way? I would do BMRs in the front and rear but I run 295/45/17 Mickey Thompsons in the back and there would be little to no gap because of the extra sidewall height. Factory springs in the rear would make the gap even.
That being said, the settings for street driving can be personal preference. Some people might like full soft.. some people might like full stiff.
The problem at hand is the OP didn't notice a difference between his stock shocks and koni's. He didn't say anything about what they were set to though, which is a HUGE factor in figuring out this little dillemma since Koni's are rebound adjustable
Reason why I asked about settings is because if the stock shocks weren't too badly worn and the Koni's are set to full soft, then he might not notice much difference. Who knows though.. some people just plain don't notice much difference for some reason
Everyone has their own personal preference obviously, but even on stock springs I ran 4 sweeps from full hard (and playing around sometimes 3 sweeps from full hard) - this should be 5 or 6 sweeps from full soft. I like the over damped, very taut feel. Spring control is spring control no matter if you are racing or not.
Basically, go off of what you like, not a specific number.
This is what I'm thinking. Did you know what the persons setup was? He could have had them on the lower perch with Sportlines for all I know, lol, which would probably blow out the dampening even in a well built shock.
OP should try adjusting his settings. Has anyone ever recommended mixing and matching springs?
I will admit that my brothers 40k WS6 stock shocks still feel pretty good. But in my case, I went from 50k Formula shocks to Bilsteins and it was night and day. Later added front Konis on the lower perch and that was another huge difference. I also settled on 3 turns from full soft with stock springs after going for awhile on stiffer settings. Comfort is more important to me than super-fast rebound on the streets of Wichita KS.
I was merely giving him a baseline and advice Strano gave me for daily driving the car with the occasional spirited driving here and there.
I talked to Sam Strano yesterday. He made a recommendation to me after asking me some questions and discussing my wants and needs. All I can say is he was awesome to deal with! He didn't try to sell me the most expensive stuff and in some cases nothing at all, when quite honestly, he easily could have. I think my game plan is current Konis on the lower perch with bumpstops, matching konis in the back, stock springs, and get rid of my rod-end lower control arms and go back to my stock ones.
