LT1 brakes...
Any help is appreciated thanks.
edit: as for whats causing it, caliper slider pins. pull the caliper off, remove the pins from the caliper, the bolts that held it on, and lube the **** out of it with antiseize
Mine were the same way until I replaced both calipers. When the car was jacked up I had to use both hands to turn the tire for the passenger side, and the driver's side would go about 1 and 1/2 rotations and stop. I did the same thing on my mom's trailblazer and her wheel spun fine for several rotations. Try what lt16spd1 said first, but replacing my calipers did it for me.
