Lowering my car tomorrow looking for tips
Alright so I'm changing my front and back shocks and springs have all the tools needed just looking for tips or tricks to make it easier and for anythin tht is usually over looked
The back are really easy. The fronts can be a pain depending on how rusted the top nut is on the stock. If it's bad you're replacing them any way you can do like I did and save the time fighting with them just cut the shock shaft and pull it out.
I'm going wit a coilover so all I need is the shock mount
LS1Tech Premium Sponsor
Like bigJ said the front is going to be as hard as the top shock mount nut is to get off. that particular nut can and generally does get really rusty and can be a pain to get off. Some kind of penetrating lubricant will be your friend.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Try a liberal helping of penetrating lube. If this doesn't work then thread the nut back on a little bit and then loosen the spring compressor and let the spring tension help push it off. Once it has come loose, apply the tension back to the spring compressor and you can remove the strut assembly.
