Do I need to remove entire sway bar to replace bushings?
Cant seem to get the damn stock rubber one out. It's in great shape just stuck in there. Got bracket off. Cant pry rubber out.
Can I loosen end links to help relieve pressure? Suspension is not my strong suit.
It's the front ones.
Please advise. Thanks.
Got them out with some lube and strength. Having a really hard time with my new bushings because the brackets are so small. Can't get them to tighten all the way properly so I gave. Especially the driver side because of the metal bracket that shares the front mounting bolt.
Thanks for the replies.
