Wheel hopping
Old Sep 10, 2011 | 01:11 PM
turyg ls1's Avatar
Default Wheel hopping
ok guys I have a wheel hopping problem when power shifting 1,2,3,&4 my suspenson are panhard bar ,Lca,lcarb & eibach pro kit springs with bilstein hd shocks ... I noticed today thar my rear wheel bearing has play in it when I grab the wheel and move it UP AND DOWN could that cause it to wheel hopp...? Any advise would be greatly apprecited
Old Sep 10, 2011 | 01:52 PM
3 pedal SS's Avatar
You need the LCA relocation brackets. The wheel bearing wont help,fix it.
Old Sep 10, 2011 | 02:43 PM
elmarro's Avatar
Old Sep 10, 2011 | 03:07 PM
ls1ya's Avatar
He has them....
Old Sep 10, 2011 | 03:52 PM
turyg ls1's Avatar
already have those on...
Old Sep 10, 2011 | 06:12 PM
libertyforall1776's Avatar
Check your torque arm mount points at both ends and trans mount -- any problems at those locations could result in wheel hop. Also, are your springs very old/sagging?
Old Sep 12, 2011 | 10:09 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
This.
Check this out. The factory TA and trans mount suck.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Sep 12, 2011 | 07:55 PM
turyg ls1's Avatar
torque arm mount is new and trans mount good also but I'm still gonna order an after market 1 and the springs I bought a 1 year ago...
Old Sep 12, 2011 | 08:03 PM
turyg ls1's Avatar
I think I might need the motor mounts cause when I pop the clutch out at regular idle and then give full throttle it sounds like my y pipe is banging against somthing ....
Old Sep 12, 2011 | 08:30 PM
bayer-z28's Avatar
^ ......... The floor board?? It's common for some Y's to hit the pass floor.
