Which drag bar?
Old Sep 14, 2011 | 10:20 AM
355z28's Avatar
Default Which drag bar?
Im trying to decide on who's drag bar to run.
UMI was fast to answer my questions, but I need a measurement to see if there mounts that bolt to the rear end will work for my 8.8 rear (since the tubes have a step in them from being slid together
BMRs I think Ill have the same issue with
WOLFE's single Bar looks like a great option for how my axle tubes are because the mounts weld to the outside of the tube but is there a down fall to this design?
Old Sep 14, 2011 | 10:38 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
we have a super lightwieght tubular chromemoly setup available that can be custom tailored to your application if need be. give us a call and we can discuss the specifics.
Old Sep 14, 2011 | 10:53 AM
UMI Performance's Avatar
What measurement do you need? The inside of the u-bolt for axle tube mounting? The machined bracket with grip teeth will be fine. Let me know and I am glad to help with what ever you need.
Thanks!
Ryan
Old Sep 14, 2011 | 10:55 AM
BMR Tech2's Avatar
We will soon be releasing a bolt-in drag sway bar to replace our current Extreme sway bar.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Sep 14, 2011 | 11:15 AM
355z28's Avatar
I would need the inside of clamp to clamp. Here the rear end i've been running. The smaller diameter outers are 10bolt tubes.
Old Sep 14, 2011 | 11:58 AM
I sent you a PM with the sizes we have to offer. Thank you, Ryan
Old Sep 14, 2011 | 01:19 PM
MidwestChassis's Avatar
It wouldn't be anything for us to alter our current ARB to work with what you are doing. Our ARB with weld on chassis tabs is $425 shipped and then you will need our sway bar stands to weld onto the housing which is an additional $30 dollars.
We do have a full bolt on version for $450 shipped.
