Electric power steering conversion (w/pics)
Is this thing ALL ELECTRIC assist, no hydraulics? Or am I looking at this wrong?
http://www.ebay.com/itm/06-07-08-09-10-11-CHEVY-HHR-POWER-STEERING-PUMP-ELECTRIC-MOTOR-EXC-SS-122279-/400661129997?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AHHR&hash=item5d4943ab0d&vxp=mtr
06 07 08 09 10 11 Chevy HHR Power Steering Pump Electric Motor EXC SS 122279 | eBay
![](http://www.fastfieros.com/tech/images/epsunit1.jpg)
Here is some more work I did on the steering column if anyone is interested.
This is for weight reduction. I wouldn't recommend for a dd.
This is the steering shaft stripped out of the column:
![Name: 20130402_152401_zps7d00071c.jpg
Size: 26.5 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607166d1501316334-electric-power-steering-conversion-w-pics-20130402_152401_zps7d00071c.jpg)
The steering shaft weighs 4lb 6.5oz
![Name: 20130402_152328_zps301ef4b6.jpg
Size: 33.7 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607167d1501316334-electric-power-steering-conversion-w-pics-20130402_152328_zps301ef4b6.jpg)
It's going to be hard to steer with this joint in it![Smokin](https://ls1tech.com/forums/images/smilies2/smokin.gif)
![Name: 20130402_152416_zps83c84bce.jpg
Size: 30.7 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607168d1501316334-electric-power-steering-conversion-w-pics-20130402_152416_zps83c84bce.jpg)
20130402_152946_zps203bdd8f.jpg?t=1364953230
Bearing and clip installed. I cut off the steering column housing at the weld.
![Name: 20130403_193357_zps30d187bf.jpg
Size: 33.1 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607170d1501316334-electric-power-steering-conversion-w-pics-20130403_193357_zps30d187bf.jpg)
Now we are at 5lbs 5.25oz including shaft, cutoff housing, bearing, and clip
![Name: 20130403_193754_zps3bb62b9f.jpg
Size: 31.2 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607171d1501316334-electric-power-steering-conversion-w-pics-20130403_193754_zps3bb62b9f.jpg)
![Name: 20130403_193804_zps91eed9cb.jpg
Size: 26.1 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607172d1501316334-electric-power-steering-conversion-w-pics-20130403_193804_zps91eed9cb.jpg)
I think it can be lighter. I cut out the weld and slid the shaft further back into the bracket.
![Name: 20130403_194651_zps7d083571.jpg
Size: 56.6 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607173d1501316334-electric-power-steering-conversion-w-pics-20130403_194651_zps7d083571.jpg)
Now I am going to cut it off at this point and rivet it together
![Name: 20130403_194657_zps35de6e58.jpg
Size: 45.5 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607174d1501316334-electric-power-steering-conversion-w-pics-20130403_194657_zps35de6e58.jpg)
Now it is about 9 oz which is almost a half pound lighter than before. it still has the bearing and clip installed
![Name: 20130403_195626_zpsce7f95ab.jpg
Size: 39.6 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607175d1501316334-electric-power-steering-conversion-w-pics-20130403_195626_zpsce7f95ab.jpg)
Now the shaft, bearing, clip, and housing is just under 5lbs
![Name: 20130403_195800_zpse72b0cb1.jpg
Size: 32.5 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607176d1501316334-electric-power-steering-conversion-w-pics-20130403_195800_zpse72b0cb1.jpg)
![Name: 20130403_195805_zps2331a2b4.jpg
Size: 27.0 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607177d1501316334-electric-power-steering-conversion-w-pics-20130403_195805_zps2331a2b4.jpg)
The sheer pins are made of plastic and you can just drill them out. I was trying to find a piece to couple the shaft that was the same size ID and my friend suggested just cutting off the lower shaft. That is what I did and it fits great and I got a 3/4" tube for the shaft and a steering shaft bearing that will be used to mount it to the car. I will need to make a bracket for this still.
It currently weighs less than 4lbs with everything, but I still need to make a bracket. Right now I have about $32 in it.
Here is the steering shaft with the sheer pins out and the cuts I made. The two parts on the left will not be reused. The only reason I took the two left pieces abart was to make sure the lower portion was hollow before I cut it off.
![Name: 20130407_191913_zpsf2b5eccf.jpg
Size: 71.0 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607178d1501316334-electric-power-steering-conversion-w-pics-20130407_191913_zpsf2b5eccf.jpg)
Here is how everything will fit together besides the middle bearing. Also the shaft needs to be cut some because it is too long right now.
![Name: 20130407_192010_zpsb58425b0.jpg
Size: 72.6 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607179d1501316334-electric-power-steering-conversion-w-pics-20130407_192010_zpsb58425b0.jpg)
Here is everything together except the bearing is laying beside it because it is a tight fit and I need to measure before putting it on.
![Name: 20130407_192057_zps8502cb0c.jpg
Size: 58.5 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607180d1501316334-electric-power-steering-conversion-w-pics-20130407_192057_zps8502cb0c.jpg)
The final weight of my steering column/shaft is 3lbs 8oz including the new bearing. I made a new bracket to mount the bearing to in the car, but it weighed the same as the old one I cut out.
This is a loss of 12lbs from the stock column.(excludes steering wheel and air bag, that would be more loss if included)
![Name: 20130427_160430_zps61bfb63d.jpg
Size: 55.5 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607181d1501316334-electric-power-steering-conversion-w-pics-20130427_160430_zps61bfb63d.jpg)
![Name: 20130722_193008_zps8eedf14e.jpg
Size: 85.8 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607182d1501316334-electric-power-steering-conversion-w-pics-20130722_193008_zps8eedf14e.jpg)
![Name: 20130722_193031_zpsd0589a4f.jpg
Size: 80.8 KB](https://ls1tech.com/forums/attachments/suspension-brakes/607183d1501316334-electric-power-steering-conversion-w-pics-20130722_193031_zpsd0589a4f.jpg)
Electric Power Steering (EPS) for less than $200
I took a slightly different approach and used an EPS system from an Equinox/Vue. No hydraulics, no fluids, no leaks.
I recently installed electric power steering in a 1966 Mustang. I did not use a kit, I simply pulled a column style EPS from a newer GM vehicle and then spliced the unit into the original steering column.
The results far exceeded my expectations and the cost was less than $200. I designed a controller that automatically adjusts assist level based on vehicle speed, so that the steering feel is "just right" regardless of speed.
I documented (with pictures) how I went about this on a Vintage Mustang forum. If anyone is interested do a google search for "Best $200 mod ever (EPS)"
or
follow this link to page 7 where the details start:
[url=http://forums.vintage-mustang.com/mod-custom-forum/787114-best-200-mod-ever-eps-7.html#post6037649[/url]..
Any questions just ask.
or
