Disc problem; overheat and spots..ceramic pads
Ok guys, I have a problem with my damn rotors; when I first got em, they got spotted really quick after 3-4 days even if I did the break in procedure perfectly. Shaking while driving was really bad.
So I got a new set from the sponsor. New ones were drilled. This set went ok for 6months and after a short trip to a local track(6laps of a short track), they were black spotted pretty bad.
Then I decided to tried to get the initial plain discs turned. They managed to remove the spot, but the discs cant be turned anymore, the guy said, cause they removed too much material.
Next, I installed the discs back for a try(brake sillicone was applied to pins/clean the old grease/buff the little dirt/dust between hub and wheels/torque wheels by hands with torque wrench/etc..).
Test drive is perfect; no more shaking!!! I'm driving my car like an old man since then(1 week) to break in setup.
Yesterday, I look at my disc; what the $%$?, black spots on the disc!!! I dont feel any vibrations for now, but why is this!!??
I'm thinking my pads might be the culprit and the disc too. Ceramic pads BTW with powerslot rotors**..I think I'm learning again that you get what you pay for..**. I think its the ceramic that is causing the overheating problem.
Last thing is I want to wait till next summer because I'm thinking about doing a 2005+ Z06 caliper/disc conversion.
Did I forget something?? I'm pretty sure not cause every other brake job I did was perfect(I've done 30+ for me and firends..). I'm no professionnal, but I take my time and put the extra effort because its my car..
They're smooth, maybe some very very minor pitting, like 2-3 1mm round spots. Other than that, they look brand new.
I'm having this problem since I got the new disc and pads. I replaced disc/pads before on my camaro without issue; I had Hawk pads with blank disc and the car was stopping way harder, but the brake dust was terrible.
You need to use high temp ceramic brake lube, otherwise the pins will not slide freely and will lock up when they get hot.
