Strut Tower Brace Bar?
#126
just ran across this from tanabe...
note that on some of the bars there are no adj screws but mounting holes are slotted...
The strut tower bar is arguable one of the least expensive upgrades that can provide a very high degree of benefit that is felt immediately after installing. Often one of the first modifications performed on a vehicle, the strut tower brace improves handling and stability of a vehicle.
Adjustable Preload
A very common error when installing tower bars, It is always recommended to raise the vehicle when installing so that the load of the shock uppermounts on the shock towers is relieved and balanced out. When raised, and the tower bar is placed onto the vehicle, the preload can be adjusted and set. After it is bolted on and the car is lowered, each shock tower will have equal load and will prevent independent movements of each shock. This will provide an extremely noticeable difference after installing. If a tower bar is installed on a car that is not raised, great benefits will be missed.
#127
I'm of the mind (convinced) a STB does virtually nothing for a stock k-membered, non-road-raced F-body. But what about where tubular K-members are used? I really hope to get a straight response without mention of waffles and the impact of light weight alloys for forks...
#128
Guys, I realize this isn't about waffles, but stay with me... I bought a tubular BMR k-member for my car when I had the motor out. Then I discovered they shouldn't be used in street/DD applications due to the single cross-tube design bending. You know, where there's a single large bar that connects one side to the other? ****. Well, I started thinking, what are the forces on that single center bar in a turn? If a tubular k-member with two parallel bars across the center is considered a road race application (by UMI, BMR, etc), could the same effect be accomplished with a STB rigidly connected to the top of the engine bay?
So your asking if having the STB at the top could help distribute less lateral force on the k-member? I don't know the official answer but I'm guessing it won't make much difference when I think about it. Extra bracing in the k-member is probably what's needed
#129
Stop trying to change the subject!
But really, I know that k-member is not optimal for DD duties. But would it be possible that the brace would "box" the k-member/frame rails/strut towers to provide additional lateral rigidity in a tubular k-member scenario? Basically, would that strut tower brace be more beneficial for a tube k-member scenario than a stock k-member?
I apologize for going
#131
Ive been ripped!! I just paid 50 bucks for a STB!!!! Oh well, same people who say they are worthless tell me msd wires are better then granatelli, " i feel as though they are at least equal"
Guess i can just use my stb as a club!!! Or put it on my car for internet bragging rights...
Lol but really , it was only 50 bucks, looks cool, and if it helps 1% then cool, if not hell you guys don't have to drive it..
#134
If Chevy put a strut tower brace on the new ZL1 Camaro it must be there for a reason.
#135
I'm not sure.. just tried to do a search on if the 5th gen has a strut suspension. If it does then that would explain why. Struts need more support the way the suspension is designed. Most strut supensions have factory STBs these days. The 4th gen absorbs most of the lateral force through the K-member.
