Help out with rear suspension
Ok I have a 00 camaro that I plan on taking to the track about once or twice a yr. Its mostly street driven. The rear suspension is untouched other than agx shocks and eibach lowering kit. I know I need to buy relocation brackets. Should I buy an adjustable panhard bar and adjustable lower control arms or save some money and get the non adjustable. Are they really needed. I have a M6 with over 500 hp to the wheels. I can probably spend about 500 bucks. Suggestions please
LS1Tech Premium Sponsor
I would definitely recommend the adjustable versions of both the lower control arms and panhard rod. I am not sure if you noticed but after you lower an f-body the rear end will move over to the driver's side of the car a bit and having an adjustable panhard bar will allow you to center the rear end back up under the car. The adjustable lower control arms will allow you to center the wheel in the wheel well if you are running big wheels and tires or running weld-in lower control arm relocation brace. If you buy the adjustables initially you will have the adjustment incase you ever need it and they are not that much more expensive.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
And the parts I suggested will work with the 12 bolt when you get it in the car. If there is anything else I can help you out with let me know.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
