question about lowering springs
I have an 02 t/a that has been lowered, bought it that way, anyway i want to go back to stock suspension, so I have a buddy with a camaro ss and he wanted to swap, so we did, everything went fine but when we let the car down off the lift on his rearend the passenger side sat a good inch lower than the drivers side, any thoughts on why?
Make sure the rear springs are fully seated in the isolators and on the humps on the rearend. Also, make sure both springs are oriented the same direction - both spring pigtails should be pointing forward
If thats all good, its not uncommon for aftermarket springs to be a tad higher on the driver side...supposedly its to compensate for the drivers weight but who knows
