- Camaro and Firebird How to Replace Brake Fluid<br>Step by step instructions for do-it-yourself repairs.
Brake fluid flush???
Like dirtbag says, a Mity Vac is a great tool that you can use to pull clean fluid through your system without introducing air or needing anyone to help you. No brake pumping needed.
I change out my fluid each year with the Mity Vac. Super Blue DOT 4 one year, then amber DOT 4 the next year. You can tell by the color when you have pulled new fluid to each wheel. Great little gadget!
I was just using your logic, that's all. Faulty logic ... but logic, none the less.
Again, using your logic and thought process, a fluid that's hygroscopic and is 100% saturated with water (brake fluid is hygroscopic and begins absorbing humidity immediately) and then sits in metal lines for 13.5 years will cause no degredation to metal parts.
Is that really how you think?
Do you ever change your brake pads? Metal backing plates will actually stop the car, so what's the point, right?
Interesting ...
Oh and in a solid, presurized system like a braking system, the fluid doesn't "move back and forth". It simply compresses, creating hydraulilc pressure. There is movement ... miniscual movement ... more at the master cyclinder and almost nothing at the caliper. But it doesn't flow through the lines like in a power steering system.
