need help diagnosing a rear susp problem
I'm going to swap shocks n check if its the shock itself. Running konis n bought em new in 08.
Any advice what else I shld look into?
I'll be switching the rear shocks on each side first. I added a new adj bmr phb last week. This problem existed before phb install.
Lca bushings are fairly new.
What other bushings shld I chk?
Car sits about 1/2" -3/4" lower on driver side rear then rear psgr side.
My phb is new and even with stock phb I was having same issue.
See years ago I hit a median on driver side... Never had this issue since till now. Frame came back good, replaced rear left lca with fairly new bushings, put adj phb, has new end links for sway.
