Adj or Non - When upgrade to 8.8 or 12 bolt
Im going to be swapping out my poly/rod ended phb and rlca's for poly/poly to cut down on noise and harshness. My question is when i upgrade to a 8.8 or 12 bolt will i have to resort to having to use adjustable?
I always suggest adjustables for any aftermarket rearend. Each rearend manufacturer will put their lower control arm bolts in a different spot, just like torque arms mount differently and spring perches are welded differently. With a PHR, sometimes it's way off, sometimes it's spot on. Having one that's on-car adjustable leaves the option open to lower the car in the future, and it also gives you the adjustment you may possibly need with your aftermarket rearend housing.
