cutting springs?
It will look hella clean when your parked but doo you care more about looks then comfort? It's going to make you feel like your driving a lowrider with every bump I've done this a few times buy the real deal and you can feel the difference. Clean f bodies by the way
Just cut em man...nothing to loose. I cut 1 1/2 coil off a set of V6 for my rear (to match ride height of DMS I removed) and it rides fine. I have not cut fronts though. As soon as I get my front drag set up installed I will have a full set of DMS lowering springs for sale w/ less that 15K miles.
I cut my factory springs on my old LT1 car. Decided to go with 3/4 coil instead of a full coil. That was my mistake. It is difficult to measure out exactly 3/4 coil compared to a full coil so I ended up with front springs at slightly different rates. Bouncing the front end resulted in a rocking effect because one side was stiffer than the other. Now I never noticed it on the street but I never felt right about it. Car seemed to ride just fine... no different than factory other than it looked much better.
My car has cut springs as well, KYB shocks. Rides great, looks great too.
Keep in mind, DONT USE HEAT when cutting springs and don't cut too much.
One coil in my case got my the desired look I wanted and kept the ride as plush as possible.
I purchased springs for my last car, what a waste of time and money. Just take a coil off your stockers and enjoy the car. If your car sees 50% racing...buy springs.
I cut my rears. that 1st coil is stacked already so it only drops about the thickness of the coil, maybe 3/4. after that cut 1/4 coil at a time thats about 1/2 3/4 drop. My car is really light so Ive cut maybe 2 full coils off to get it to sit flush (I run 28" tires)
